1 - 13 of 13 Posts
sometimes when i get on it i see smoke in my rear view. not from the tires. i give it some juice and i watch the rear view and i see a plume of white smoke. i have 6000 miles on my car and it should be broken in by now. is this a bad thing? i don't mean driving real hard, but i am pushing it. let me know crossbow. you sexy thing you.
Probably just running rich, and some condensation. Its dark, oily smoke you need to worry about. I'd say you're OK.
Probably condensation in the exhaust. Nothing unusual. :)
i get a lot of soot as well, but haven't noticed smoke. i wouldn't be overly concerned.
is it when u first start your car? it takes a while for both cats to warm up. the one closer to the turbo lights up pretty fast, thats why u see the temp needle get to the middle quickly. the second one is a lot slower. a good indication of when the car is warmed up is when the idle rpm drops to 750.
it was after i turned the car on, but it hadn't been sitting for too long since i drove it last. i only noticed it because i just randomly looked in my rear view and i saw the smoke. it was white, but also dark outside. everyone seems to be ok about it so that makes me feel better. thanks guys.
edit:
first post i made when i was drunk that wasn't absolutely retarded. rest assured this occured before i was drunk and not during.
the temp gauge has nothing to do with the catalytic convertor. It is the temperature of the coolant, which takes awhile to warm up - more or less depending on the temperature outside. Obviously, it will take longer to warm up if it is 0 degrees out than when it is 90 degrees out.
I'm wondering if this car will pass emisisons inspection. I think people should get their cars inspected ASAP while the car is still under the 1 year / 12,000 mile period. Mazda will cover a failed emmissions until then I think. Or am I wrong and it would be covered under the entire bumber-to-bumper?
i'm not too worried about emissions, unless i move to california. my title was market "not california emissions compliant". thankfully for me i have no plans on moving back to cali.
think emissions warrnty is 8yr/80k what ever it is it is beyond the factory warrnty
I get it too...usually after flooring it.
Usually only happens first couple of times. When I am backing up in a dark area (sticking my head out the window) I can smell the fuel. So most likely a "rich" condition. 3422 miles and counting. I expect it to subside a bit after I get some more miles on it.
I got my Speed6 down in Georgia, but plan to move back to NY in August. Since my car did not have the "NY/Cal, etc... emissions" option on the list, am I going to have trouble passing my NY emissions when I move back? I wasn't sure if that option was an actual piece of hardware that was on the car to reduce the emissions, or if it was more like a tax if you live in one of those states.
Anyone got any ideas?
-Jesse
1 - 13 of 13 Posts
