Will the lugs on the 03 16' steelies work for the 04 17' oem rim?
Discussion Starter #2
n e one?
As long as the lug nut has the same taper as the lug seat on the rim, there's no problem. Since most original equipment wheels use the same type of lug, they should be interchangeable. It's when you get into aftermarket wheels that you have problems with lugs. Here's an example of the types of lugs:
Most original equipment wheels use the Ball/Radius type and many aftermarket wheels use the Conical/Tapered type.
