Use an offset calculator and the specs of known hellaflush fitments to calculate poke.
18x8.5 +30 will be pretty flush. If you run a 225/40 and dial in a little camber, you can run them no problem.
If you have to ask someone else about specs and such, you probably aren't prepared to run a hellaflush set up. There are going to be a lot of hidden costs and problems you will run into when you daily drive a flush set up. Just make sure you do your research first before committing to something like this.
