Soo, I’ve had my Mazda 6 2013 2.2D SkyActive for about 6 months and racked up about 19k miles. The car has today hit 100k miles.
started having issues a few months back but now it’s getting worse. Engine starts fine and idles ok if it’s cold it does idle high but I’ve been told that’s normal ?
when I’m driving I get a lot of delay for acceleration and when the engine reaches about about 2k rpm a lot of stuttering and rocking, this happens in pretty much all gears after 2nd.
Last night I decided to try and push the engine to see if I could get it hot and force a DPF regen and what I noticed is that at around 85mph the car would not go and faster and with the pedal to the floor I actually started loosing speed but when I lifted my food and put it back down it would speed up again to 85. After a few attempts at this it then exceeded 85 and seemed to be normal
I should add I’m not a maniac on the road and do not drive excessively fast this was all done on a private road
my plan for this weekend is to do the below;
Change the fuel filter
Clean map sensor
Clean maf sensor
Clean throttle body
Change air filter and cabin filter
(Oil and oil filter was changed about a month or so back)
is the throttle body easy to remove and clean and where exactly is it on this gen ?
(I have very little mechanic knowledge but do have a interest and think the best way to learn is to do)
will the above solve the issue ? Has anybody got any ideas to what else could cause these issues ?
Thanks in advance
Joe
Clean map sensor
Clean maf sensor
Clean throttle body
Thanks in advance
Joe
