1 - 3 of 3 Posts
OK when I used to push lock (with my remote) it would lock and the hazards would flash, then if i pushed it again it would honk, letting me know 4sure it was locked (good thing)
Also, when I unlocked it would flash-
Now nothing.... it locks and unlocks it but wont flash or honk.... but my panic button will do it, and the horn n all that are working...
Why? it really bugs/confuses me b/c I haven’t messed with anything inside the car....
Also, sry if this isn’t the right section to post this in....
Thanks alot-
verify all doors are shut, also check your rear hatch/trunk. This is usually a case when the vehicle "thinks" something is open. Even if it may not be. Usually its a bad trunk/hatch pin or possibly a hood pin if your model has it. Check those first before you go diggin into it. Ive seen this happen on mostly honda's and vw's though. Ohhhh and also ford hood pins
1 - 3 of 3 Posts
