1 - 8 of 8 Posts
or you dont need to take off the entire door panel, just pull from the bottom and you'll hear the pins snap, just feel around and put the 194 socket back into the hole. shouldnt be too hard... all the doors are the same, not sure which door led you popped out... passenger or driver?
yes sir, pull the bottom of the door panel.. put your fingers behind and put the socket back... otherwise you can take the whole door panel off if your more comfortable with that... (un-necessary though)... to do that remove the rubber mat under the door change holder thing (take out screw #1) and then behind the door handle, still inside the car theres a plastic piece that comes out, thats screw #2.
other than that start at one side and work your way around its just popping out clips.
lemme know if you need any help!
I accidentally did the same thing! :doh: but ya just take off the panel you should find it there. Be sure to put up pics! I got some red ones and they look amazing :D good luck!
you can watch this video for install tips,
and our bulbs do not just fit in like that.
its kinda similar but two smaller lenses, this would be appropriate for the rear however.
1 - 8 of 8 Posts
