1 - 9 of 9 Posts
hello everyone ,
I have a little weird problem on mazda 6
When I release the throttle pedal and you want to slow down or sometimes when you accelerate and the car shift up .. the car randomaly brake randomaly like "cutting", its feel like you on manual transmission and you shift down earlier and the car brake to you and the revs up but its happend like this without the revs really up
When the car "sit" and doesnt drive for a while its happen often
No warning lights or something
Cant find where the problem is
2016 mazda 6 2.5L without turbo
Thanks for help
2015 Mazda6 Touring MTX
What you're likely noticing is a tuning characteristic of these engines. For whatever reason (likely fuel economy) Mazda tuned their engines to cut fuel often at low speeds, sometimes resulting in some noticeable jerking and engine braking under no/partial throttle conditions. As far as I know, nobody has found any real way to resolve the jerkiness, though some people report that using premium grade gas helps smooth things out.
Discussion Starter · #5 · (Edited)
Yes , its really help , I tried that already
Thanks for the info mate
Yep many other people reported it and Mazda said it’s normal. It has to do with something along the lines of the engine and transmission trying to work as efficiently as possible I think. I drive a friends 6 the other day as well as a 2020 CX-5 and it does the same thing. You’re good!
[QUOTE = "مستهلك بالمياه ، نشر: 5069153 ، عضو: 292922"]
هل يحدث هذا فقط عند السرعات المنخفضة (أي الترس الأول والثاني) أم بسرعات عالية أيضًا؟
[/يقتبس]
نعم لدي نفس المشكله تحدث علي السرعات المنخفضه
1 - 9 of 9 Posts
