My 07 Mazda Speed 6 is spraying gear fluid out while shifting.
Nobody can tell me what the part is called to replace it. Any ideas??
So you want us to magically diagnose a car spraying out transmission fluid out over the internet? With no pictures. And no car history.
Having said that, your blinker fluid is probably overfilled - wouldn't worry too much...
Seriously, give people some real information. Post some pictures. Where is leaking from? How much and how badly? Is this the original transmission? Have you ever done any work on it before? Did you just replace something else on the transmission?
It's a manual transmission that has never been replaced. The mechanic tried to tell me my transmission was leaking but it isn't, it's the gear fluid running down the side of the trans.
Was it refilled or taken apart recently? I had an issue on a manual transmission Ranger where the seal between the shifter and the transmission had a leak. Ended up just being a gasket.
