Keyless ignition, no ACC, red key
397 Views 4 Replies 2 Participants Last post by  Tamás
Dear Colleagues,
I have a problem with my 2009. 2.5 GTA manual Mazda6.
Key opens the door, but when I press the clutch, key icon turns to red.
I have tried both keys (also the physical keys), replaced the key batteries, I checked the fuses, and the car battery.
I tried to connect with OBD2, but since I have no ACC, without any success.
In the forum several Colleagues had similar issues, where the steering wheel lock module was the problem.
I found some pictures from a module, but it is for a diesel engine.
Can someone send me the part number for a 2.5l? Is it possible the same?
Thank you.
Automotive lighting Car Automotive design Steering part Motor vehicle
Tool Font Adapter Gas Auto part
Automotive lighting Road surface Asphalt Rectangle Bumper
Camera accessory Watch Automotive lighting Gadget Camera lens
Did you find a solution for this, I’m experiencing the same problem with my 2010 Mazda 6 2.2 Diesel Manual
Unfortunately I haven't found any solution, but I did found a local Mazda specialist nearby.
I estimate a few weeks for the repair, I will keep you updated.
Thank you so much
It was the steering wheel lock / immobilizer module. The Mazda specialist replaced it for a used module, cost was around 400EUR key reprogramming included.
Reactions: 1
