1 - 20 of 24 Posts
I have a 2008 Mazda 6. I have two key fobs. One I use regularly with no issues. The other is on my wife's keys. She tried to start the car the other day and came in and told me the battery was dead. This is impossible since I had recently replaced it and drove the car myself only hours before.
I took my key fob and had no issue with starting the car. I later tried her key fob to only find it not to start the car. It unlocked doors with no issue but when I tried to turn the key over to start the car, all I got was a humming noise and a click but no start.
QUESTION:
Do I need to replace the key fob?
Do I need to replace the battery in the key fob? (DONE as of July 6)
Do I need to reset the key fob? (DONE as of July 8)
Any answers are certainly appreciated and happy 4th to all!
Thanks!
:bowdown::bowdown::bowdown:
if it clicks, still mostly likely battery related. bad batt, poor batt install, or failing charging system
Reactions: kdrew
Discussion Starter · #3 · (Edited)
No luck with battery change
Thanks for the response.
The car battery was installed correctly and the car works fine. No alternator problems or any other electrical issues.
Decided to change the battery for the key fob. Unfortunately, the change of battery (CR 1620) did not do the trick. Can still open the trunk, unlock the doors, etc. As soon as one turns the key, you get a "humming" sound and no start. :eek: :eek:
Thus I ask for any other helpful insights. As mentioned, the other key fob works fine.
Thanks for looking and I hope that I am not the only one that has experienced this. I find it very odd that one key fob works fine and the other is doing as described above.
take it to the dealer. they have certified mechanics for a reason, right?
Still no luck
Thanks for the response. Unfortunately, the change of battery (CR 1620) did not do the trick. Can still open the trunk, unlock the doors, etc. As soon as one turns the key, you get a "humming" sound and no start. :eek: :eek:
Did the reset. Both keys did as it was supposed to but the wife's key fob still will not start the car. Very odd.
Probably may be cheaper to buy a new key fob than go to the dealer.
Discussion Starter · #6 ·
Key fob still not working....
Thanks but I was hoping to avoid the dealer for a key fob issue. This doesn't really make a ton of sense. Apparently, I am the only person with a Mazda that this has happened to (which I find hard to believe).
:D:D
Discussion Starter · #7 · (Edited)
A solution.....sort of........
For all those out there that happen to stumble across this thanks to a search engine, I learned several valuable lessons.
First off, I learned how to change the battery in my key fob which was very simple actually (which was unnecessary ultimately).
Secondly, I learned that the chip is actually in the "key part" of the key fob.
Supposedly, the chip in the key can become deprogrammed but apparently cannot be damaged by typical everyday usage.
My key chip (the one in my wife's key fob) somehow became deprogrammed. The odd part is this - IT COULD NOT BE REPROGRAMMED!!
I went to a local locksmith whom I found extremely reasonable and was only going to charge me $10 to reprogram the key chip and nothing if it didn't work. The dealer wanted $95 to "diagnosis" the problem which I think needed no diagnosis....but I digress
:huh:.
The technician plugged the car in and tried to reprogram the key and was given an error code saying that the key was unable to be programmed. He said he only sees that when people buy the wrong key of the internet. I explained that it was the original key that came with the car. He was dumbfounded as am I
:confused: .
The good news is that I avoided the dealer and got a new chip key (cut) and reprogrammed for a very reasonable price when compared to the dealer.
I am still at a loss on how this could occur
:eek:. I hope this helps someone out there in internet land. :) :) :)
Not the remotes battery, the cars battery
If the key lost programming, the car wouldnt try to start at all, no clicks, no nothing. Just a flashing security light in the instrument cluster.
I still say its the cars battery.
Discussion Starter · #9 ·
Sorry but I disagree............
Sorry but the car battery is fine and was just changed. As I stated, both remotes came with the car when I purchased brand new from the dealer. My remote is fine even after the battery change. The other key fob was rarely used but did work and then suddenly stopped working. It would not start the car and would only give a humming sound when one turned the key.
The technician said that the instrument cluster did show a flashing security light. This is what was so puzzling since it should have been easily reprogrammed. The beauty of the internet is that some other poor person with the same unusual problem will hopefully not waste as much time as I did and move onward at a lower cost than buying an entire new key fob and wasting so much money at the dealer.
Thanks for the follow up but I disagree with your assessment.
:D :D :D :D
It could just be one of those mysteries where it just stops working for no reason... like reverse lights... Byakuya... lol
Ahhh. So u do have a security light flashing. That says it all. Flashing light = immobilizer issue
However you also did state you heard a clicking when u try to turn the car over. Clicking with out the engine turning is a sign of a dead battery, hence the suggestion.
If the engine keeps turning over, never fires up, And there's a flashing security light, the ECM is not recognizing a valid key therefor not allowing the car to fire up.
Oh yeah, let me correct myself. My previous reply was wrong. Most Fords and Mazdas will turn the engine with an unrecognized key. It just won't fire up and give
U a flashing security light. I have plenty of these expierences when I have to install remote start systems.
that humming noise is the fuel pump priming up.
And it is possible to bump a programmed key out of memory when too many keys are in close proximity and cycling the ignition.
Glad u got it fixed tho
Reactions: kdrew
The car became a sword beast. It's gonna soon b consumed by a hollow.
LOL
Discussion Starter · #14 ·
Thanks. This thread will enlighten some poor person with the same issue. Perhaps I need to review prior posts since it made a click not a clicking sound. The simple fact remains- one key fob worked and one did not. Both were factory issued with the car and one was used all the time, the other was not. Somehow, the chip got deprogrammed and was unable to be reprogrammed.
Like you said, I'm glad I got it fixed. Thanks again.!!
Although this is an old thread...I am experiencing the same issue. I am posting to see if anyone ever came up with additional solutions in the last year. I have one working and one non working key. Both will unlock the doors but only one will start the car. I own a 2012 6i
Clearly the chip lost it's ability to start the car. The click causing all the controvicy is an electrical noise that sounds like the starter motor click that happens when the battery is too dead to turn over the starter. Well the immobilizer works the same way and the click definitely does happen when the key unlocks the ignition, but the chip fails to be read, or is read but not recognized as the correct chip. Incidentally the chip is located in the plastic housing of the key part of the controller. It's a small plastic block that looks like a part of the plastic casing, but on closer examination it can be seen as a slightly different color. If you need to replace the housing, bear in mind that the correct chip & key combination must be together to start the car. If the chip is not functioning & the warning light on the dashboard confirms this state then go to a key cutter & have them code a new chip from your spare key. The Mazda dealers will charge a fortune to do this so avoid them if at all possible.
Bumping this for future reference.
I just swapped out fobs after my original had the key ring part break and you are right! There is a chip in the switchblade part of the key that I hadn't transferred over. Car started right up afterwards.
In case it helps anyone, I bought a shell from China to save $$ and it was missing a cutout for the panic button and the tolerances were wack as well. It served its purpose, however
For this issue it is the key. The chip pebble inside the key could have gone bad for some reason. No one knows why or how they go bad but if you have one that will start the car and the other will not it's definitely in the chip or pebble inside the key not sending the correct info to the cars ECM. Only way to fix this is to get another key. Changing the battery doesn't do anything that battery is only for the keyless entry in the fob and has nothing to do with the immobilizer pebble.
:huh:.
:confused: .
Hey, I have the exact same problem, just bought a used car and one key starts and unlocks and the other only unlocks.
The dealer wanted $120 to reprogram it. @()*&)(@* dealers!
Thanks for your post. Now I just have to find someone cheap to reprogram it.
:D :D :D :D
I know this is a long time after your post, but I am having exactly the same issue. My key and fob works absolutely fine, my wife's key & fob was working fine and just stopped working the other day, we changed the battery in the fob, no change except it would open the doors & unlock the boot, it just wont start the car, however if i remove the cap where the key goes put the key in & push the start button the car will start. I have looked online for how to reprogram but nothing works. So it would seem to be I will need to get a new key with chip then get it cut & reprogramed.
1 - 20 of 24 Posts
