Hi Guys,
Just picked up this mazda6. Cool car, yet I've already noticed an issue that is really concerning me.
When I'm at a light and the car is idling, every now and then the rpm drops to just about 0, then shoots up to 2k, and then levels off again normally. It will do this intermittently. It has also dropped so low at times that it has actually died, although it starts right back up.
The weird thing is I have no check engine light or any codes. I've been told it could be a small vacuum leak that isn't big enough to trigger the check engine light. But at the same time, if it didn't trigger the light, I would think the idle problem wouldn't be bad enough to make the car stall.
Any other things I should be checking for? Sensors, something not connected, etc? I've had it looked over by a mechanic and he says he doesn't see any bad vaccuum hoses. Just trying to find out if maybe this is a typical symptom for these cars, and if someone knows the problem.
Any and all help is appreciated. Thanks in advance.
