1 - 7 of 7 Posts
I finally found the wiring diagram and the took the trunk wire from keyless entry and connected it to the remote starter trigger. Done! with the help of the immobilizer by- pass.
Reading Topic: I've installed a remote start to the keyless entry
Are you saying that the remote start is already equipped on the car? Pressing the trunk key starts the car? This probably can't be done on a manual huh?
Replying to Topic 'I've installed a remote start to the keyless entry'
I had a separate aftermarket remote start. I just installed it, I disabled the trunk feature on the keyless by cutting the trunk wire and connected it the remote start. (I can can still use the trunk release in the car). Now I need a on -off - on toggle switch so I can switch between trunk and remote start on the keyless. If you need a I can explain it all. :D
OH yeah , THIS SHOULD NOT BE DONE ON A MANUAL!!!!!!!!!!!!!!!!:(
1 - 7 of 7 Posts
