I had to take my car in to have the brakes looked at and they ended up resurfacing the rotors because they were warped. I got out after driving back from the dealership and I looked at the rotors and it's pretty clear where the pads are contacting vs where they aren't. On the drivers side there's about 1 1/4" of shiny new metal where the brake pads are making contact and the rest of the rotor still has the crosshatching from resurfacing. The passenger side is only about 1". I went out to drive it for a while and the drivers side seems to have bit a little more into the rotor and it's about 1 1/2" down now but the passenger side is still the same. Is this normal, because it sure doesn't *seem* normal (but the brakes seem fine, stopping as well as they have in a while). Will the brake pad geometry be changed with warped rotors to the point where there's a high spot on them? Will they eventually be worn back to normal, if so how long will it take? And the amount of brake dust is just stupid on both wheels leading me to believe that the pads are being ground down and will eventually be flat and able to make contact with the entire rotor, although I'm not expert. Any ideas?
