I'm in the market to buy a used 6, and took a look at one at a dealer. It's an '05 with the V6, and when I took it for a test drive, it exhibited two problems. First, there was a bit of a vibration and a rumble at highway speeds which was definitely from the wheels and not the engine (the sound didn't change when I put in the clutch and let the engine idle). Second, the car produced small puffs or clouds of smoke from underneath the right side of the engine compartment after I parked it at the dealer and let it idle with the hood open. The smoke sort of puffed out from the right wheel well area, then went away, then a minute later another small cloud puffed out from under the engine.
The dealership says that their mechanic checked these problems out and found that there is a bent rim that was causing the vibration and rumbling, and that they'll fix that. That sounds plausible, and shouldn't be hard to test if I go back for another test drive. For the smoke, they say that the oil filter is right over the exhaust, and when they changed the oil, it was done sloppily and leaked onto the exhaust, making the smoke. They claim they've cleaned that up and that it shouldn't be a problem.
Does this explanation sound reasonable? Is a messy oil change capable of dripping oil onto the exhaust? The smoke puffs did seem to come out at periodic intervals like there was a slow leak from somewhere that was dripping onto the exhaust. I only drove the car for maybe 10-15 minutes, so it seems like a one-time spill would have either burned off completely in that time, or would have made a continuous cloud of smoke. What I saw seemed to indicate a leak that was continuing to drip onto the exhaust.
Thanks for any advice...
