1 - 9 of 9 Posts
I'm like huh???? I don't know and I didn't find any info on this here?
no.
some oler cars used the fr s-bar as part of the lower control arm (VW), so in that case it was.
Sway bars should de deactivated when corner weighting, but that's usually a coil-over thing
no.
Sway bars should de deactivated when corner weighting, but that's usually a coil-over thing [/b]
actually you want to do your final corner weighing with the bar(s) hooked up. if adjusted properly they should not add or subtract from any of the corner weights.
I asked about it a long time ago, and the short answer was no. When I had the shop install mine, I told them to perform an alignment if necessary....and no alignment was necessary.
The only thing that the installer needs to be worried about is getting holes to line up again.
Does the sway bolts have to be undone/remove???
It depends how careful you are installing the front bar. If you drop the entire subframe, then it could skew the camber/caster. If you remove the steering gear from the subframe it could make the steering wheel crocked, though total toe will stay the same. Either way it won't change much and the bar itself does not affect the alignment in any way.
Older Saturns also used the bar as a control arm, so on those cars it could have an effect.
1 - 9 of 9 Posts
