1 - 8 of 8 Posts
  1. I was recently in an accident and i need to replace my headlight ive been calling around but nobody has any for my 2004 mazda 6 and i was curious what other years (if any) would fit instead of an 04.
Administrator
Sorry to hear about you accident.
If you have the integrated fog lamps (located between the turn signal and high beam), then you need a '03-'05 headlamp with integrated fog. If you don't (if you don't have any fog lamps or they're located in the lower bumper), than any headlamp from a '03-'08 should work fine.
The only thing I need to mention is that the '06-'08 headlamps very slightly from the '03-'05 (mainly a black insert compared to chrome), so you may wish to replace both of them if you do go with '06-'08 versions.
Good luck.
Reactions: Byakuya
Good luck.
Everything he said - image for reference:
Administrator
If you have the integrated fogs, you'll have a secondary rotary switch on your headlight stalk that turns them on/off. If not, then you do not have the fogs.
It's tricky, because the headlamp units in the '03-'05 models have a lens located in the integrated fog, whether or not the foglamps are actually in there or not. The only other way to double-check is to look at the back of the headlamp unit and see if there's a bulb and wiring connected into the foglamp position.
2003 Mazda 6S
Thanks. Yeah I don't have a secondary rotary switch, just the primary one for the head lights. I'll probably install some in the bumper someday
@Mz6GreyGhost can correct me if I'm wrong but I thought you could swap out the stalk and it would work, but I might be forgetting that you need to run new wires, so don't quote me.
Probably correct, asazda usually put the harnesses in place. However, a big factor would be sport or non sport bumper.
1 - 8 of 8 Posts
