1 - 20 of 21 Posts
Hey guys, the problem is that the info display and the radio is not working. But where the radio connects to the car, the plug is different, so it looks like the radio was replaced and is not the right one. My question is: are all the 6 cd-players interchangable? (it has bose system) Or did they change them within the years? it is an 05 model. Thanks for yor help!!
The LCD info display is definitely connected to the "radio". Actually there is a circuit board behind the trim panel for the radio/climate control stack that talks to the radio and climate control and then controls the info display.
There was a change in LCD displays in around 2005-2006. I believe the 2003-2005 models had an LCD display with a 16 pin connector and the 2006-2008 models have a 12 pin LCD display connector. Cosmetically the design of the trim panel and radios were changed in around 2005 as well... the older models have brushed aluminum finish panel and the newer models are gunmetal-color with chrome edges and piano black finish radio face.
I can't say for the newer models, but for at least the older models, the radio units were a "modular audio" design. The CD player unit could be swapped from NO unit to single CD to 6 CD changer to MP3 CD, and the tape unit could be swapped from NO tape to mini disc to cassette tape just by replacing the modules. So theoretically if you had the 6 CD changer with cassette tape, you could unbolt and remove the top CD changer module and the middle cassette tape module and you would still have a working radio with FM/AM.
The Bose "radios" and the non-Bose "radios" should have the same plug connectors but with different wiring pinouts. The Bose radio harness runs to an external amp whereas the non-Bose units drive the speakers directly. The Bose radio has line-level outputs where the non-Bose has amplified speaker-level outputs at the same wires. Otherwise the wiring at the back of the radio is almost the same.
I can't say for sure, but theoretically the CD and tape modules should be the same whether you had the Bose or non-Bose.
Hope this helps.
Hope this helps.
Picture 1
ok, in this picture the connector circled in RED does not match the car, the car has all stock wiring, everything fits like a glove, except the circled part in red, is this why the information display does not work???
The radio, cd, climate control... everything on the dash board works, but the info display.
Picture 2
This is the back of the information display, the connector fits perfectly with the car at side A. Is there suppose to be something at side B? because it looks like an empty spot.
So is the info display not working because the part circled in RED does not fit?
Thank you guys!!!
The circled blue connector is suppose to connect to the stereo, but like i said it does not fit, only fits on the display, maybe it has a wrong connector?
Does anyone know what the connector circled in green is for???? maybe that is where the info display connects to?? or no??
Hi
The connector that you circled in RED at the top is supposed to be for an external CD disc changer that I believe mounts in the trunk. Some iPod adapters use that connector, so don't worry about that.
The back of the LCD that you labeled A and B... is supposed to be like that. It is not missing a connector, there is only supposed to be one connector on the back.
The LCD unit you have appears to have the 16 pin connector which I believe is the 2003-2005 model like mine. The 2006-2008 models I believe have a 12 pin connector.
The connector you circled in green... is connected to the LCD display. There is supposed to be a short cable with a long and flat rectangular end that plugs in to the circuit board, and then the other end is a short and stubby rectangular white male connector plug that your LCD display connector plugs into. It would mate up with the end of the LCD display cable that you have above.
Referring to the image above that you made the circle in red... there is supposed to be a bracket in the top left hand part of the image that this male plug clips onto just like that connector in the top right hand side of the image that sticks out diagonally. That piece of metal sticking out in the top left of the image is the bracket where that male connector clips onto. You can see that piece of metal bracket more clearly in the image where you have labeled "A" and "B"
Note that it also appears that you have a mismatch, I think you have a 2003-2005 type LCD display and a 2006-2008 type audio unit.
You are definitely missing a cable there, but I can't say for sure if you would need a different LCD display unit as well. Take it to the Mazda dealer and see if they can order the cable. You might need the 2003 type pigtail which has the 16 pin plug. But I can't say for sure if the 2003 pigtail will plug into the 2006 circuit board. At worst you would have to buy the 2006 pigtail and a 2006 LCD unit.
See here for a picture of the 2006-2008 LCD display unit with 12 pin connector:
Ebay 2006-2008 LCD
See here for the back of a 2003-2005 radio unit to get an idea where that "missing" connector is:
2003-2005 back of radio
Hi
Ebay 2006-2008 LCD
Yup, I realized this all, when I went to the dealer and they gave the whole assembly in pictures, Im in fact missing a cable that from one side connects to the dash and the other side sits on the metal part where LCD would plug in.... thank you!!! we figured it out.
I was also wondering if you might know where I can find the pin-out diagram for this stereo, for the connecter circled in red, like which is the aux, R+, L+, signal and ground, because I want to wire a 3.5mm connector... thank you!!!
I have a similar problem with my Infodisplay. But my show: _ _ _ - - - - - - - - _ _
Dunno why. I've checked all the cables and they are ok. So could it be the Base-unit or maybe the unit inside the trim? I guess it should be a faulty Base-unit. Because if it wasn't, it should at least show some information like ACC or Stereo. But it shows none. But any advice of what to do?
i have the same promblem with my stereo i have a 2005 mazda 6 with a 06 head unit so where does the lcd display wire suppose to fit at
if you swap to the 06+ radio, u need the 06+ readout, and cable also. the cable runs from the radio, right to the screen.
and i fixed my screen yesterday!!! hasnt worked since i bought the car in 06. for the 1st time ever, i know what time it is. and that it actually tells me the outside temp. i had no idea! lol
i have an 07...where does it tell you outside temp? thats the one thing i have always looked for.
okay now i have the 07 radio with the 07 display and 07 cable but it doesnt fit on the radio , the 2005 6 had a extra plug on the left side of the radio which the never 6 doesnt does anybody know how to splice the harness togther so my lcd display will work
eCommerce Office (no parts located here)
4955 Kalamath St
Denver, Colorado 80221
[email protected]http://www.lkqonline.com866-557-5787
llllll.jpg 05radio i am missing the upper left harness to the radio i have the harness to the lcd display
another question is when i had the metra kit my display never worked also was there a way to splice the harness to make the display work
Wait if you have the 07 radio with the 07 display and 07 cable, why are you trying to plug it into the 05 radio?
I'm trying to do the same thing you're doing btw, so I can get the new nav/gps unit from foreverstarcar.
I have an 03' broken display and I would love to swap it out to one of the 06'+ as far as I know they are not as prone to failure. Is it possible to just swap the pin connectors? If so does anyone have a wiring diagram on how to accomplish this?
1 - 20 of 21 Posts
