I have a 2004 6i, auto trans, 68k miles. Recently it developed the infamous knocking sound that many 2.3L owners experience. This is hard to track down from what I've read on all the Mazda/Ford forums online.
When the engine is started cold, it SOMETIMES makes the knocking sound and if it does, its for maybe 2-3 seconds. Once oil is warmed up, it's barely audible at idle. If I free rev it (in PARK) it doesn't knock until 2500rpm or higher. I'm guessing it's coming from the valvetrain and hopefully not the bottom-end.
When driving, it only does it when as the RPM's climb towards 3000 RPM and when the revs drop during a gear change. When I'm cruising and speeds 30mph to 65mph it's SILENT
I pulled the valve cover and turned the crank 2 times CW and put a wrench on the intake cam. I followed what the service manual says about turning it back 90 degrees and listening for a knock in the VVT actuator. I did notice a small amount of play from within the VVT actuator gear.
Could all that noise be from the VVT? Yes one would think so, but I also noticed quite a bit of slack in the timing chain between the IN and EX cams too. So could it be a bad timing chain tensioner?
I'm sure someone on this forum has had to go through this before. I've searched all over with people saying they had this problem but haven't come across a DIY or write-up on how to troubleshoot this and repair it.
Any ideas would be very helpful to me and others who come across this in the future. Thanks
