Dumb question, but I'm not sure what map I am currently running on my car. I know it comes up when you see it, and I name my maps pretty long, so perhaps I'm just missing it. Anyways, I was almost positive I was using a specific map w/ tweaks to the wgdc tables, but for some reason my idle was set to the stock values (700ish rpms). When I looked at my map on my laptop, I couldn't find any that matched that did NOT have the 950rpm increase that I do.
So basically, is there anyway to download the current map that's flashed from the AP to your computer? Maybe I deleted the original map off my computer, I dunno. That shouldn't matter, but I do need to find it, as everything else is all set up in that map, except my idle, and maf cal.
TIA
· Premium Member
Using the AP, go to "Tune" and you'll be able to see the current map being used... file name + description. Once you've identified the map, you should be able to download it using the AP manager.
Yeah, I tried that, but maybe I messed up. I'll have to write down the full name this time as the names are lengthy. I'll try late tonight, thanks!
Discussion Starter · #4 ·
NO DICE. My AP screen shit the bed about a month ago when my car was still AFU. I went to "show current map" and it comes up as "Unknown"!!! WTF?! The weirder thing is, all my other maps are on there when I go to change map :/
I think I'm just going to use the map that I THINK I have (the one I want to run anyways), and adjust that maf table with the maf g/s logs I took today. Worst case is the maf gets screwed up a bit, and then I just re-cal it. It hasn't been off more than +/-5 in forever, and that's with adding a bunch of stuff to the car, and not calibrating the maf.
I'll post up what happens :O
