Why?(leave the rear and Ebrake to the shop)
No. You cooked your rotors as you described.My question is, does anyone think changing from the 1 pot Mazda OEM caliper to and aftermarket 4 pot caliper would help?
A shaking steering wheel is basic stuff, not a high tech. The most logical mechanical device that causes steering wheel shake comes from a warped front rotor!so iv had the car for over a year now (2016 Mazda 6 sport) and approximately 5 months ago I started to develop an issue with the brakes. The car will shake at speeds of 35-50 mph when slowing down. Iv had the rotors changed about 4 months ago in the front(they said pads were like new, but I changed them today to ceramics to make sure) I’m going to check the back pads and rotors today. Is there anyone having this issue or anything recommendations. Like I said the front rotors are like new and I just did the pads today please help it’s shaking pretty bad now probably going to go out of service until fixed.
This is the exact reason i went with Centric rotors, they actually machine them on a lathe (not a brake lathe) to within a specified matched tolerance.One was warped beyond limits so I ordered a reputable brand replacement from Amazon. When it arrived, it checked the run out of the brand new rotor before putting the brake back together, it also was warped beyond limits. I contacted Amazon and they expedited another one, checked it and it was fine.
Using a Dial micrometer, check the runout on both sides each of the four rotors. The allowable run-out will be published in Mazdas service manual. Sorry I don't have those spec's perhaps another member does.so iv had the car for over a year now (2016 Mazda 6 sport) and approximately 5 months ago I started to develop an issue with the brakes. The car will shake at speeds of 35-50 mph when slowing down. Iv had the rotors changed about 4 months ago in the front(they said pads were like new, but I changed them today to ceramics to make sure) I’m going to check the back pads and rotors today. Is there anyone having this issue or anything recommendations. Like I said the front rotors are like new and I just did the pads today please help it’s shaking pretty bad now probably going to go out of service until fixed.
Yes, one needs to leave the rotors on the car.And it is possible to use that without removing the rotor? You'll have to excuse my ignorance with cars. 😀
I aggrege, If after the new rotors were installed, the lug nuts were not properly CROSS TIGHTENED to the correct torque, the new rotors could be warped.A shaking steering wheel is basic stuff, not a high tech. The most logical mechanical device that causes steering wheel shake comes from a warped front rotor!
If you can't tell which rotor is warped turning it by hand you have to set up a means to determine if it is. Remember, it is not recommended to run your front wheels with the engine while hanging down unsupported because of the stress on the CV joints if that idea comes to mind. Brake rotor run out is usually done with a 0-1 inch micrometer. I set mine up using vice grips and other tools necessary to get the micrometer in position so it's measuring button rested on the outer portion of the rotor to determine which one was warped. One was warped beyond limits so I ordered a reputable brand replacement from Amazon. When it arrived, it checked the run out of the brand new rotor before putting the brake back together, it also was warped beyond limits. I contacted Amazon and they expedited another one, checked it and it was fine. Put everything back together and the vibration was gone.
The point is, just because a part is new does not mean it is a good part, especially something like a brake rotor.
@TalonTsi90 because the electronic ebrake requires disengaging the system and I have never learned to do that.....so I just have the shop do it as it's quick.Why?
Start button twicebecause the electronic ebrake requires disengaging the system and I have never learned to do that
If you have replaced most/all things related to the brakes then you’re issue may not be the brakes but the suspension (the linkages most likely). I had a similar issue with my gen 2 Mazda 6 and I thought the issue was my brake pads or something when it was actually faulty bearings and links. Hope this helps a littleso iv had the car for over a year now (2016 Mazda 6 sport) and approximately 5 months ago I started to develop an issue with the brakes. The car will shake at speeds of 35-50 mph when slowing down. Iv had the rotors changed about 4 months ago in the front(they said pads were like new, but I changed them today to ceramics to make sure) I’m going to check the back pads and rotors today. Is there anyone having this issue or anything recommendations. Like I said the front rotors are like new and I just did the pads today please help it’s shaking pretty bad now probably going to go out of service until fixed.
