Yikes! I hit the mother of all potholes yesterday driving in Maryland..... god I had Maryland and I heart Virginia..... well anyway there was a car to the left and right of me, it was impossible to miss, I slowed down a ton but I still hit it at about 30-35 mph.
It ended up bending my rear rim EVER so slightly. I got out of the car and took a quick visual look at it and didnt notice anything. Then after shopping I checked it again and rubbed my finger around the edge of the rim and I found roughly a 2-3 inch section slightly bumping out. I ordered a new rim from tirerack so it should be here Monday and I will have it installed next week. However I am going on travel Monday-Wednesday of next week and I NEED to pick up some stuff this weekend and drive. Personally, I dont think I am going to have any problems driving the car around on a slightly bent rim over the weekend but I figured I would offer up my predicament to anyone who might have had a similar situation. I know I should have taken a picture of the rim, yadda yadda yadda, but it happened late at night and I am at work now, I didnt have the time.
Thoughts?
....just to add, I believe the "bent" part is only on the outside of the rim. I drove very very slowly over a level parking lot to see if I could feel anything with the car and it felt perfectly normal. I examined the rim and noticed that the bump did not go all the way across the width of the rim, it was only on the outside portion of the rim.
The only thing I might do, if I may suggest. Swing by a wheel and tire shop and have them check the balance. The shop may be able to spin-balance the wheel pretty close to where it needs to be. At least you won't have a wobble and take the chance of chewing-up your tire. Have them check it for leaks as well. The shop should have a dunk tank or at least a spray bottle with a bit of soap in the water. Good luck!
This should hold you over until your new wheel arrives.
keep an eye on your tire pressure too. you might be leaking air.
I bought a new rim last night from Tirerack and I was going to replace it next week..... cause im anal like that. I have a bubble reagent and I was going to bubble test the bent area to see if it was leaking when I get home from work. If it wasnt leaking, I was planning on driving on it this weekend to do errands. Im not gonna worry about balancing it because Im going to swap it out in 5 days when I get back.
Just curious if there was anything else I forgot about or if anyone had any similar situation...... thanks for the replies.
