Hoping someone might be able to help identify this whistling sound coming from under the hood. I got the car up and running after about a year of sitting, due to the cost that I was quoted to fix some misfires (That's a whole other story). For the most part things were running well, but after a few weeks of working on it, this humming noise started happening.
The noise starts after the car is warmed up, while in any gear, and only lessens above 20mph or so. At first I was thinking a bad alternator diode, but the battery is still getting fully charged around 14.2V when running. The other reason I don't suspect the alternator is because the noise doesn't stop until after the car is shut off. I just replaced the drive belt and idler pulley. All other pulleys seemed to be in adequate working condition. A stethoscope indicated somewhere near the rear of the engine, or possibly below the vehicle. It's hard to pinpoint exactly.
Live data on my OBDII reader shows that the long term fuel trim shoots up to 20% when I'm not actively pressing the accelerator, so there's very likely a vacuum leak somewhere. i figured it would also be present when the car is cold, and be more of a high frequency hiss if it were from a leak. Unfortunately I haven't been able to get ahold of a smoke machine to test for leaks.
My only thought was that it may a leak in the exhaust manifold, but my knowledge there is pretty limited. Everything I know about cars has been from the dozens of hours spent reading and researching this one. Here's a video that shows the sound. Taken from my phone, above the drive belt. It's loud enough that folks can hear it inside the house while it's running in the driveway. Any thoughts?
