Is the V6 overrated or underpowered?
I've been reading some discussions on this board and some on the Countour boards and the dyno numbers
of the 6 with the V6 are really too low to not be taken seriously. Why are they that low?
At 20% loss the automatic should see 176hp and the wheels, it doesn't. At 15% the manual should see 187hp, and it doesn't.
I'd like to ask what octane fuel is being used in these tested cars? Also, if low octane is being used, as is instucted, is it possible that the numbers listed by Mazda are from using higher octane?
I just find the dyno numbers to be too low for the stated output. The new 3.0 Duratec tuned by Ford is putting out better HP and torque numbers in the Mondeo.
I think Mazda needs to answer this issue. If I'm paying more for more power, then I want that power and I don't want less.
If some of you have dyno numbers please post them and post the fuel that was used and obviously auto or manual.
Also, note, that in automatics there can be a BIG difference in power output if the trans and fluid are hot. The hotter the trans gets the less power it might provide.
Maybe we can get some data together and if the data warrants it, we can send a letter to Mazda and ask for an answer.
Tome
Tome
