1 - 8 of 8 Posts
It is built into the panel and does not com out as a separate piece. You just remove the whole door panel as one piece after removing the 2 hidden screws.
The hidden screws are located in:
1. Door handle, it is covered by rubber.
2. Door switch, which I believe is actually visible. I can't locate the pictures but you should be able to find it easily.
Discussion Starter · #7 ·
An acoustic engineering fellow has "keep_hope_alive" as a youtube channel on sound control in vehicles, car stereo. Knows his stuff. Click the hyperlink... Also, see other very gd site.
1 - 8 of 8 Posts
