Hi folks. Long timer lurker, first time poster.
I've got a 2014 '6 with a drivers side rear door panel/trim that has come loose (see photos). This is the flexible vinyl/leather (leatherette?) material. I can tell that it was previously attached with some kind of adhesive, since it is still sticky. Has anyone else seen an issue like this? I searched quite a bit but I could not find anyone with this same issue.
Any suggestions on how best to fix? My initial thought was to clean off the old adhesive as best I can with alcohol, and then use 3M 77 or 3M 90 spray adhesive, masking off the rest of the door to protect from the inevitable overspray. Ideally I'd probably prefer some kind of brush-on adhesive but I'm not sure what to use here (I may just spray the spray stuff into a cub, and then brush it from there).
I'm in Texas, so it needs to stand up to triple digit heat.
Any suggestions welcome.
Thanks!
Thanks!
