1 - 20 of 73 Posts
Originally posted by Jax6S@Aug 10 2005, 05:08 AM
You can upload it by using the "add this attachment" button or
You can host the pictures somewhere else and link it to your post by using the "IMG" tag.  (preferred way).
[snapback]481012[/snapback]​
Okay lets try this again, this time play like I'm an IDIOT and I really don't know what your talking ab out.....
:drive:
When you're adding a new post, below the area where you type, there are these sections:
Post Options
Post Icons
Attachments is the one that I'm talking about if you want to attach your picture to the post. The result will be like this.
Now for the second option.
Go back to the area where you type your post. Above the area where you type, there's some tags. Stuff like: B I U Font Size Color, etc. One of the tag is IMG tag. If you click on this tag, it will ask you where the actual file is located by using http:// command. Thus, you have to host your picture files somewhere and using this IMG tag, it will automatically load up the pictures that you are hosting somewhere else.
For example, look at this. The first picture that you see is actually located at this address: http://memimage.cardomain.net/member_image...036_87_full.jpg
But he linked it to his post using that IMG tag.
I hope that helps a little.
Post Options
Post Icons
[snapback]487892[/snapback]​
Thanks, I'll go to the practice fourm and see what I can do.... :drive:
Good job Jax.
<-------- How do I put picture there?
click on the "my controls" link at the top of the page. then change avatar settings.
WHY cant I post Pictures?!?! I was able to a Month ago, and now it seems on Every thread I post to I get an error:
"Upload failed. Please ask the administrator to ensure the uploads directory is writeable"
the pictures are small enough so they should work
Anyone else having this problem?
And I think "writeable" should be "writable"
it's already been brought up in the site trouble section, being looked into. nothing to do with you.....or does it?!?!
links to pics on things like photobucket still work fine though
1 - 20 of 73 Posts
