1 - 10 of 10 Posts
I have a THB cartalk and want to instal it on my '04 6 , non-bose audio sistem...and i need something, to conect a wire that has written on it : " car-radio muting, NPN connects negative". I have this car kit from a friend and it was instaled on a 2003 ford focus that had a wired special for this..someone can help me ? Thank's!!
Also, my english is a little rusty... :)
10Q man, u're a life saver :) ..First thing in the morning i'll try it..if i have the time...
OK..so this afternoon i started installing the car kit..Didn't found any Black/Red wire coming out of the CD conector, i put a wire thru the "1L" pin, tested it and it worked fine. Until i started to close everything...something gone wrong..When i put my 6230i on the cradle, it's begining to charge and the radio ( CD player ) is mutted even thou i don't make a call or receive one..Tomorow i shell test everything again...Damn, and i was so happy..talked to a few people from my car...when testing...Can't sleep thinking of what gone wrong..
i'm not sure what the input for the mute line is, but i'd imagine it's ground (-). therefore, anytime ground is sensed on "1L" the radio will mute. double check the mute output from your hands free kit to ensure that it signals ground (-) when calling.
it's gound..It's written even on the wire that come from the car kit..."conects negative" ...I tested ..it worked for 3-4 calls..when tried to seal everything up..i think i touched something, 'couse everytime since the i try to putt my phone in it's cradle..the ardio gets mutted..
i'd double check your wiring to ensure that your new mute wire isn't shorting to ground behind the radio.
It's working..thank's god...I'm stupid.... :) The cradle has on it's back a plate with a magnet..if you take that away..."mute" is on... stupid me !!!
glad to hear you got it working. enjoy!
Discussion Starter #10
10X man!!!..i'm so happy 'couse i did it :)
1 - 10 of 10 Posts
