21 - 29 of 29 Posts
Part numbers changed?
Thank you for the informative write up! I have a 16' Touring as well and wanted to see if paddle shifters were possible. I had a few questions:
I tried doing the same thing by looking under a 16' Grand Touring
I found the rear cover as well as the paddle shifters specific to the 16 Mazda 6 GT; however, I was not able to find the wiring harness specific to a 16' Mazda 6
I clicked the links on the OP to the wiring, rear cover, and paddle shifters on mazdaswag's website and the compatibility kept showing Mazda 3. Is this correct or did the part number change?
Thank you for any help! Don't want to buy the wrong parts.
for models 2018 this looks a little be different.
The back cover has 2 screws additional to the clips (#1), and
Have 4 clips that the new ones do not have. (it was necessary to cut them)
Also in the new model to remove the airbag is a little different (laterally, not as indicated here), there are 3 side holes in the back cover (I had to do them in the new cover in order to future to be able to remove the airbag again if necessary).
It was not necessary to change the clockspring or to cross the 2 cable with ground from the star / stop Unit to the clockspring. These cables are installed from the factory.
In general you can not see any adaptation and everything looks as if it were original.
Some day I will get the exact back cover for my model and I will change it again.
100% recommended modification, driving with this, is another driving experience.
Did you purchase the parts from the same links the OP had??
Administrator
2021 Mazda6 Carbon Edition
Sorry. I had to do some cleaning up, due to off-topic posts that had no business in this thread.
Consider that a warning. Please keep your posts related to the DIY, or there will be consequences. Thanks.
Reactions: toy4x
Hello all,
I know there is scattered information everywhere about installing paddle shifters on Sport and Touring Mazda 6s. After reading as much information as I was able to find online, and going to a dealership to get part numbers from a 2016 Grand Touring (got a vin number from autotrader lol), I bit the bullet and ordered the parts.
Disclaimer: I am not responsible if anything breaks on your car. This is a pretty simple upgrade, so don't worry, nothing should break (Except those little black tabs <img src="http://forum.mazda6club.com/images/smilies/mad.gif" border="0" alt="" title="Mad" class="inlineimg" />) if you follow the steps.
PARTS:
Wiring: (BNK8-66-4M2) https://www.mazdaswag.com/oem-parts/mazda-wire-bnk8664m2/?c=aT01NDE5MzM1NSZyPTEw
Rear cover: (GJS2-32-049) https://www.mazdaswag.com/oem-parts/mazda-rear-cover-gjs232049/?c=aT01NDQyNDA1NSZyPTM=
Paddle Shifters: (BHT1-66-3P0) https://www.mazdaswag.com/oem-parts/mazda-paddle-switch-bht1663p0/?c=aT01NDE5MzM1NSZyPTY=
Bolts: Two options, local harware store, or Mazda ones. You need 4 bolts total.
-A: (GJS2-32-750) https://www.mazdaswag.com/oem-parts/mazda-paddle-switch-screw-gjs232750/?c=aT01NDQyNDA1NSZyPTg=
-B: #10-32 x 1/2 in. Round-Head Combo from your local hardware store. Mine: (http://www.homedepot.com/p/Everbilt...-Steel-Machine-Screw-3-Piece-814391/204274805)
I decided to order everything at the same place to keep things simple. You may or may not find those part cheaper in other websites. My total cost was $180.44 before shipping.
The bolts I ended up buying at the local hardware store. Paid $1.18 for the pack of 4
NOTE I can only confirm this parts work perfectly for the 2016 Mazda 6 Touring, and most likely work on the 2016 Sport. Do your research if you do not have a 2016!
TOOLS:
21mm socket - To remove the steering wheel nut
10mm socket - To remove battery negative terminal
Flathead screwdriver
Phillips head screwdriver
Cutting Pliers
Blue Threadlocker
1. Loosen the airbag. At this point my car is on, so I can easily turn the steering wheel.
--- A: Use the Phillips screwdriver to push the tabs in the back of the steering wheel. There are 3, two on the sides, and one in the bottom. Picture below is for one of the side ones.
--- B: There is no need to use excessive force, as just pushing the screwdriver in will push the tab, and you will see the airbag come out a little.
--- ? Once the airbag is loose, DO NOT REMOVE IT YET, make sure the wheels are pointing straight, and turn off the car.
2. Remove negative battery terminal. SUPER IMPORTANT as we are messing with the airbag. You do not want it to go off while you are working on this.
DO NOT plug the battery back in without the airbag in place, this will most likely cause a check engine light that cannot be easily erased. Read about this on my online research
3. Once battery is unplugged, time to remove the airbag.
--- A: There are 3 plugs to remove, the highlighted green one is a ground, which pulls straight out.
--- B: The 2 red highlighted ones are the important ones. You can see a back tab on top of each one, you will need to use a small flathead screwdriver to pull it up slightly, as pictured.
--- ? Once the black tabs are extended, both entire plugs will pull off with you hands. They will take a little bit of force, but they come off. I DO NOT suggest you use anything other than your hands
--- ? Pull the airbag off, and set it aside, don't throw it around or put it on the floor to step on it lol. Back seat for me.
4. Take out the steering wheel
--- A: Unplug the white connector, highlighted in red
--- B: Take the 21mm socket and remove the main bolt. You will need to hold the steering wheel so it doesn't turn when you start putting pressure on the bolt.
--- ? Pull off the steering wheel. Note the airbag plug stays on the car
5. Remove the back cover of the steering wheel by pinching the 4 plastic tabs in red below. I did it as you see in the picture, putting pressure in the back with one hand, and used a screwdriver in the other hand to push down each side of each tab. (Thinking about it now, you can probably just use some pliers)
6. Remove the Steeering wheel controls to change the wiring
--- A: Pull off the plastic connector highlighted in pink
--- B: Lightly pull the tall plastic tab highlighted in green, and push the control out a little so it is not locked. (This is the tab the a lot of people break. Don't worry if it does)
--- ? Use a flathead screwdriver to put pressure on the two red plastic tabs and pull them out. This ones are really tight in there, so you will use a little bit of force. Put the tip of the screwdriver right on the base of the tab, so you don't break anything else.
--- ? Once those 3 are out, the control comes off.
--- E: Do the same to remove the other side
7. Switch the wiring
--- A: Cut the two zip ties highlighted in green with the cutting pliers
--- B: Unplug the blue connector and plug in the new one. Then unplug the gray connector and plug in the new one. (One at a time to make sure we don't plug the wrong cables)
--- ? The new wires come with 2 new zip ties to replace the ones you just cut out. Put them in.
8. Put the controls back on the steering wheel, and plug back in the white plastic tabs highlighted in red in place. Note I had not put mine back on the picture below.
9. Put the back cover on
--- A: First put the paddles on the back cover, and route the cable along the path, highlighted in red.
--- B: Put the complete back cover on the steering wheel with pressure, the 4 plastic tabs will click
--- ? Use the 4 screws you purchased, put a little bit of threadlock in each one and tighten the paddles with 2 bots on each side
10. Put steering wheel back on the car
--- A: Connect the white connector highlighted in red, this is the new one for the paddle shifters
--- B: Put the steering wheel back on the car, use some threadlock on the bolt and tighten.
--- ? Connect the white connector highlighted in green back on the car, and make sure the ground and two wires for the airbag are outside, like the picture
--- ? Make sure the steering wheel bolt is reeeeaaallly tight. I did not find the torque number needed, so I just made sure that bolt is tight in there, use those muscles.
11. Put the airbag back on the steering wheel
--- A: Connect the ground cable
--- B: Connect the two airbag connectors back on, and press the black tabs back down. The connectors are color coordinated, so plug the right ones in.
--- ? Push the airbag back in place with pressure. No battery means the horn is not going to go off lol
12. Plug the battery back in and go enjoy those paddles!
I'm trying to figure out how to ask this question, so forgive me if it doesn't quite make sense: I have not tried this yet, but plan to. I notice that the center hole in the steering wheel (the mounting slot) is hexagonal. Is the spot it mounts to also hexagonal? Like, is there a hexagonal pin sticking out of the dashboard after the steering wheel is removed, or is it circular?
I ask because I want to do this but I'm not confident that I'd be able to put the steering wheel back on perfectly straight. But if is a hexagon shape then obviously it would be easy.
Hello all,
PARTS:
TOOLS:
Cutting Pliers
Blue Threadlocker
It is a hexagonal cone, where there are only 7 faces, if you skip one you will see easy that it is out of phase. I recommend using a permanent marker, so it's easy to put it in its position again.
I posted a guide on Mazdas247 forums for how to do this to the 2017 Mazda6 but I cannot post links or images since my account is new.
I wanted to share with you guys here so if you go to that forum you can find it by going to this section:
Forum > Mazda6 > Mazda6 How-To > Installing Paddle Shifters on 2017 Mazda6 - Requires Minor Modifications to Parts
If someone finds it and can post links it would be great if you could post the direct link here as well.
Hello,
I know it has been a long time I would like to do this to my own 2014 Mazda 6 Touring.
For those that have done their 2014, do you have the list of part numbers you used? It appears they are different than the 2016 above for a 2014?
I would very much appreciate the help.
Thanks in advance,
Dave
AharkY
17 Blue Reflex Mazda 6 Touring
Wanted to say thanks for the great write up. I bought a used steering wheel from a Grand Touring on Ebay ($95) and then swapped the wiring harness and rear cover onto my wheel since it was in better shape. Easier than expected and the only tab I broke was on the extra steering wheel. I am well pleased. Thanks again.
242231
242230
242232
Reactions: fernando8877
21 - 29 of 29 Posts
