Really useful, thank you @Archerfish
Yes, I forgot to mention it. I actually have a stool which I used to support it. Of course, it's best to use a wire. I realized it when I was doing the rear brakes.- folks would want to not strain brake hoses; accordingly, hang-up caliper with wire when you remove it from its frame;
I don't know what are the differences with the lubricants you posted but the one I used says that it is safe to use in rubbers.- use made-for-brakes lubricant (hi melting, no petroleum content, therefore good with rubber parts); do not use a conventional petroleum-based grease;
Right! I only realized it when I secured the last wheel. I will do that once I have the mechanic install the caliper repair kit.- use a very small amount of *NeverSeize" or alternate to preclude corrosion forming between rotor and hub when reassembling;
Boy 'o boy does that rear caliper dust seal look lousy 🙁. I ask, rhetorically, how did it get to be that way? @Archerfish , you don't have that many miles on it...Yes, I forgot to mention it. I actually have a stool which I used to support it. Of course, it's best to use a wire. I realized it when I was doing the rear brakes.
There's a tool where it looks like an S. That's what I saw the mechanic used.
Here is the picture of the rear, and it's badly torn.
I already bought the front caliper kit but the rear kit is not available. If anyone knows where I can one, kindly post the link.
I think I have an idea how it happened. I don't remember those Mazda boys using the "maintenance mode". What I remember is that they used a tool to push the piston back by forcefully turning it.Boy 'o boy does that rear caliper dust seal look lousy. I ask, rhetorically, how did it get to be that way? @Archerfish , you don't have that many miles on it...
Re getting the rubbers-only / rebuilding kit, you're having trouble finding it?
