[1] User a breaker bar to crack the wheel lugs.
[2] Jack the car up.
[3] Place jack stands under the car
[4] Remove the wheel and place to the side.
[5] The crank sensor is located next to the passenger side axel and is secured with an 8mm bolt.
[6] Replace crank sensor and tighten back the 8mm bolt.
[7] Plug the connector back onto the crank sensor
[8] Put wheel back on car
[9] Finger tight the wheel lugs
[10] Jack up car and remove jack stands
[11] Lower the car and torque lug nuts back to spec.
