1 - 3 of 3 Posts
Out of curiosity, my knowledge about electrical components is very limited for now, I'm not at that module at school yet (I got my paint prep exam on Tuesday)
Copy/paste of the specs:
Two Pole Induction Motor @ 3400 RPM
Oil Lubricated Direct Drive Pump
115V, 60Hz, 15 Amps
5.1 SCFM @ 40 PSI
4.1 SCFM @ 90 PSI
Maximum Pressure: 125 PSI
75% Duty Cycle
3.0 Peak HP / 1.3 Running HP
5 Gallon Twin Stack Air Tanks
Cast Iron Cylinder
Thermal Overload Protection
High Flow Regulator
Tank and Outlet Pressure Gauges
Dual Quick Connect Coupler
If I hook this up using a converter, would the alternator be able to make this baby work wiuthout damage to the car? or am I better filling it up on an outlet and use whatever air I got until the next fill up?
I'm leaving for 5 weeks for work, and would be fun to be able to put this in the back of the wagon and able to do some airbrush anywhere I want. :lol:
thanks
Sounds like what you have is an workshop style compressor that you would have in your garage? The problem I see with that is you will need an inverter that can put out at least 1800 watts, which requires direct wiring to the battery and alternator and will run between $200 and $300, plus the added weight of the unit itself, plus the sound of it running.
Ok, thanks. Will let go off the idea, my inverter only does 100w, bought it for the laptop and the fm transmitter.
Yeah, it's a small workshop compressor, but not big enough for the heavy tools. I use it for airbrushing and nailgun. Doesn't give enough air for a cut off tool.
Sound isn't so bad, I use it inside the house. Weights less than my golden retriever :p
1 - 3 of 3 Posts
