As it states, I took the cover off and that little hose in the front of the BOV it keeps ripping. Is ther a way to prevent it? I've been threw 5 hoses already..
You need to rotate the head of the valve so that the nipple is on the bottom of the valve, away from the IC cover. It has 6 or 8 screws that are not a pleaseure to remove, but once you do, rotate the cover and re-attach. Problem Solved.
