1 - 20 of 26 Posts
2015 Mazda 6 Sport
Are there any high flow cats for this platform, I’m trying to see any other options besides corksport to enhance the exhaust system?
2016 Mazda 6 Touring AT, coilovers 1.2" drop, OVTuned, Injen CAI, Thrush Exhaust
I'm planning on cutting out the stock cat and replacing with Flowmaster 200 series high flow cat (technically not legal in California, but fine anywhere else, also this is the secondary cat anyways since I'm not touching that beautiful stock exhaust header).
If you still have the big restrictive stock muffler I'm not sure it would be noticeable, but if you already have a better flowing muffler then should free up a few ponies (2-5 depending on calculations, mostly in higher RPM).
Reactions: ABCGarage!
The second cat is already tiny. Replacing it with a high flow cat wont make any difference whatsoever.
A muffler upgrade is 1-2hp which will be negated by poorer aerodynamic performance. Its actually not very restrictive either, as the design is good
Nostalgic Hero put in a set of headers (which does not include the pre-cat). He retains the underfloor cat. I wonder if (and you said the underfloor cat is smallish) you could go to a high-flow underfloor cat, go to the same headers that Nostalgic Hero has... and then (obviously) NOT be emissions legal on start-up... but become emissions legal once the car is up to operating temp?
It appears that this approach will yield some decent results, say, if you combine with an axle-back decent system.
I realize this goes against what you said earlier re not wanting to muck with the stock system.... but....
Having one high flow cat or simply keeping the second cat wouldnt be quite legal in terms of emission production, but just about.
How much power will a high-flow cat really give you? I was under the impression that modern catalytic converters aren't very restrictive in the first place.
It's mainly the design of the stock manifold which will cause restriction, and in this case the design is good. So the answer is, probably not enough to warrant being barely emissions legal.
2015 Mazda 6 Sport
Can you give me a link to this high flow cat, I'm curious to see the price and design.
The external size of a cat does not necessarily indicate the amount of resistance it may be creating, though my understanding is that older cats are more restrictive and would thus be a larger difference.
I've noticed you claim 1-2hp for the muffler, which seems like a significant underestimation, and it is a giant muffler so while it may not be that restrictive considering how much it quiets the sound it is still a lot of restriction/loss of exhaust gas energy.
To be fair I don't have a dyno graph to measure the exact difference, but my muffler upgrade was a VERY noticeable difference on my butt-dyno with the car pulling faster and just feeling like there was less lag between pushing the pedal and the car moving. If it were only 1-2hp I don't think it would be that noticeable. Also in my case I think it is hardly any aerodynamic reduction and about 40lbs lighter.
I think I've mentioned this before, but anytime we're talking about intake or exhaust then you have to consider the cumulative changes. It is often the case that on a stock car with nothing else changed just doing an Axle-back exhaust upgrade will hardly net any performance benefit, but if that same car has other mods that are allowing it to flow more air (e.g. Tune, intake) then the benefit of the changes to the exhaust will be amplified. Same is true for the cat, where the benefit may be unnoticeable in otherwise stock form, but noticeable if the exhaust is already flowing better and that cat is now a key restriction point.
In the end it is entirely conceivable that a high flow cat change might not be noticeable (though I doubt that, with my setup at least), but <$100 for the possibility of a few more ponies seems like a worthwhile try (I am not going to do anything crazy like turbo this car so looking to squeeze all I can out of it within reason).
I don't have it off hand at the moment, but just look on Amazon for 2.5" 200 series cat (that is important, the 200 series is the metal substrate with less cell density, which means less restriction or flow interference). I think it's like $60, I'm going to unbolt the mid-pipe myself then take it to a local shop to cut out the old and weld in the new for like $10.
(Technically it's a Christmas present from one of my kids :), but I'll try to snap some pics comparing stock to the new one when I get it done).
The muffler on this car is only big for aerodynamics purposes- if you cut it open, the piping inside only makes up a small portion of the internal cavity. It's a Hemmholtz resonator design which is actually quite excellent at managing exhaust back pressure with overall flow. I say 1-2 hp because no matter what sort of muffler design you're dealing with , no matter how restrictive, its the most gains you can physically gain from such an upgrade. I changed the VERY restrictive muffler on my BMW out for a magnaflow back in the day and while there was a difference, I swear it was no more than 2hp and only winding out past 4500rpm. It's more of a sound mod than anything else.
Mazdas stock exhaust is a great design and I wouldn't say it's very quiet at all in stock form, hence the potential to squeeze any power out of it, especially being an NA motor is very limited. Youd get a better result swapping out the huge factory resonator for something high flow.
As for the second cat, it is a very small cat both in terms of size and the number of cells it has. Its just for warmup emissions meaning it's not supposed to be big. Plus I believe its monitored meaning it's a bad idea to mess with it. Honestly, replacing it would probably make zero difference whatsoever.
On a turbo car, a cat elim pipe can be worth 30hp depending on the rest of the mods done.
To each their own I guess, in the end I am most happy with the sound (went with classic turbo muffler) and was pleasantly surprised that it felt a little snappier on the throttle.
Interesting that you mention the resonator, it had never occurred to me, I thought a resonator wouldn't impede flow at all?
2015 Mazda 6 Sport
Discussion Starter #16
Perfect, I think I may also do this. Let us know how it goes :)
Well, resonators dont impede flow, they "resonate" the exhaust airflow which can sort of be described as a good or ideal type of turbulence, meaning if you were to delete the resonator all together not only will it likely sound like raspy sh*t but you're probably going to lose some power too. It turns out the factory resonator is pretty big on these cars and it sounds much better if replaced with a high flow glass pack. Modzas has a video on it.
cool, now you've got me thinking about changing the resonator while I'm at it (would never consider just deleting the resonator as a want it to sound good)
2015 Mazda 6 Sport
Discussion Starter #19
These are the videos he's referring to, I made these awhile back, but still valuable information.
Installation of Vibrant Resonator:
Sound Comparison:
Reactions: WoodinvilleDan
I finally got the high flow cat installed yesterday and while I was waiting at the muffler shop I started to worry that I wouldn't notice anything, but I was wrong. I could not be happier!
Naturally it makes a difference at high RPM, but the real shocker is that it is a noticeable at very low RPM, particularly it feels like it takes less throttle input. Obviously it's a subtle improvement just SO happy that it is noticeable.
@ABCGarage! This is the specific Cat I installed (though it was a little cheaper when I bought it) Flowmaster 200 Series 2.50".
@TalonTsi90 hopefully it holds up and Flowmaster doesn't do me wrong, but the muffler I'm running is not Flowmaster it's a classic Thrush Hush Turbo Muffler which has been fantastic.
per commments from @MazdaMoisturization, the second cat is not monitored only the one in the manifold/headers.
This has really got me thinking about how impressive these Mazda engines are, really amazed at how much they seem to be able to capitalize on changes in exhaust and intake. Last weekend I attended another Autocross and literally had 12 people walk up to me between runs asking what have I done to my car to make it sound and move like that, one of them even asked what V6 I had swapped into it!
1 - 20 of 26 Posts
