hello guys,
I am adding and extra lights and would like to take the + from the hi beam, but I can not find it,
any idea which color is it ?
I tried to find it with a tester but no luck
thanks a lot and if you can help with pic, that would be great
hello guys,
I can't remember what year and specifics you have but the wiring diagram for my 2004 says the following.
Left High Beam = G/Y (green with yellow stripe)
Left Low Bean = R/L (red with blue stripe)
Right High Beam = L/G (blue with green stripe
Right Low Beam = R/Y (red with yellow stripe)
Mine is 2003, I guess it is the same
BUT
THANKS A LOT MAN you saved me .:thumbup:
my car is Mazda 6 model 2003 with DRL
I tried to connect the led ramp to my Hi. beam, but I think something wrong with the wiring or maybe my bad experience with Japaneses cars.
the issue is I tried to connect from the right side wiring (Right High Beam = L/G (blue with green stripe) it worked,
BUT when I switched the Hi beam off, it is still on.
switch the whole lights off the led ramp went off.
I tried the other side it was the same issue.
I tried to wire it from the fuse box but OH SHIT when the low lights are on the fuse of the Hi lights are on also but the lights itself are off.
I connected the wire to the fuse (10 amp) which is the hi beam, the led ramp went on but the hi lights itself are off.
what is going on with this issue.
its done
I took the wiring from the bulb wires itself
it is now
Lo beam Dual color Led
Hi beam 8000k
Led bar
Fog beam led
