Hi guys I came with a question maybe some of you experience this with your Mazda 6 or with this engine.
After i switch the gear fron 4 to 5 for example and i accelerate i have 1 second pause after that car pulls fine. This happens only sometimes. When that lag occur continue to do that even if I only accelerate.
I had change fuel filter, no leaks near injectors. So if any of you experience this please. Thank you
Discussion Starter · #2 ·
Ps: the car is a Mazda 6 2.2d se-l 2013, i use it to commute so 70-80 percent is driven on highway, i change the maf sensor as well
Hi OP, did you get to the bottom of this I have the same issue? I notice it right after a gear change in every gear if I'm accelerating any more than gently. I'll try the MAF sensor too but seems you already tried this? I've only had the car 2 months though so I wondered if it was just how they drive? Hopefully not. Mine is a 2016 with 40k miles.
Discussion Starter · #6 ·
I don't think it's how they should drive as long it's happen only sometimes, at least for me
