I had my alternator die on me this past weekend. I took it into a local shop my family uses to have the alternator rebuilt. When the alternator died, I was parked outside a restaurant picking up some take out. when I walked back out to the car, I put it in gear and began to pull away and within the distance of the next 10 feet, the car went into safety mode (3rd gear) and my headlights went out. Weird thing was that my high beam blue interior light came on yet I had no headlight @ all. Today, I picked up my car and the mechanic said it was completely rebuilt and the battery was recharged. I get in and let the car warm up and pull away a few moments later. About halfway home, I go to turn on the lights I suddenly realize that I have no lights. I make it home before the dark comes and take a look at everything. Light assessment is as follows:
both the left and right brake lights work. the brake light bar on the wings works. Both rear turn signals work except the right rear one flashes faster (usually indicating a blow out fuse or bulb). The front low and hi beams do not work and the front left turn signal works but the front right turn signal does not. Also, the drivers done window )power) doesn't go down now but all the other three do. Radio works, horn works, door locks works, alarm works. I initially thought it could have been the body control module but based on the normal traits of a failing body control module it seems not likely. I can only be led to believe that during the time the alternator went out, it took the lo and high beam bulbs out and the right front turn signal bulb as well. If anyone has any ideas or help, it would be greatly appreciated.
