1 - 10 of 10 Posts
Alright well ive spent all day installing my halos. But during the process I managed to yank one of the wires out of one of the halos. Now i can still connect them back but I would need to solder it. Well i didnt have any so i used some adhesive stuff. It seemed to work for roughly 40 minutes and then stopped working. Now the question is should I just buy a new halo for that one or should I solder it and it will work fine again.
What I noticed is that the halo pulses and lights up very lightly. So to me that sounds like the halo is messed up, but i have no idea. I also made sure everything was connected and made sure that both power sources were fine.
Basically do you for 100% know that if I solder it, it will be fine again, or should I go ahead and get another halo.
O ya these are the new halos not the old ones.
Discussion Starter · #2 ·
bump
i had a problem with my halos also, all i did was email apexcone (the makers of the halos) and they emailed me back with an answer by the next day. heres the link Apexcone. hope that helps
no longer needed i fixed it, but thanks for the help sinister.
MODS you can close this now
Only after you tell us what was wrong and how you fixed it! My thoughts are a bad connection from the patch job.
Discussion Starter · #7 ·
Alright in all honesty I dont think I did anything really I took it all apart again and took the halo off, then went and plugged it in and it lit up, so the I reatached it to the bezel and retested, it still worked. I put the bezel back into the plastic shield tested and still worked. Put it all back together and tested it and still worked. Then I drove up my street to see if it was still good after being on the road, and guess what it was out. I was pist went back to my house cursed, Hit my headlight then went for a drive again. Sure enough its working and I drove around town making about 8 stops on the 15 minute journey and at every stop it worked. So basicallly I have no idea what I did, it works and im happy.
i dont think im satisfied with your solution...
Discussion Starter · #9 ·
Its true man very true. Think it has to do with the angle the wire comes out from the halo where I screwed up and it gets snug as shit when you screw the blinker light frame back in, I think that has somethin to do with it. I have no idea but that what went down. Worked in my favor tho now im able to take my headlght apart and back together in like 25 minutes.
I hope it stays working ya. I definately want a set for myself. Since your a pro at taking it on and off now, maybe it'll take us less than a couple hours to install my set next time. :D So did u secure the ballast?
1 - 10 of 10 Posts
