Hi, I am new inthis forum and wonder if any of you know how to correct the flicker problem with the DRL (Canada model) with the HID kit? Any hlep would be greatly appreciated.
Discussion Starter · #4 ·
Just to update, I follow one the link that t mo t provided and it works perfectly. However, I did not cut the brown wire under the dash and grond it to disable the DRL. Instead I made a ground wire and connect it to the negative (black) wire from the hid kit and ground it to the nearest bolt. When this is done, releasing the break would turn on my headlight without the flickering problem (and this is exactly how I want- to have DRL on). Have anybody had any problem with this procedure so far? Thanks.
