1 - 8 of 8 Posts
Got a question! * has anyone had one of these fail & cause it to run bad *
Timing solenoid oil control valve....
I’ve got some videos of what the scan tools reading while idling..
idles fine, you got to rev and it sounds like it’s spazzing out? Like the timing goes out when start to rev or something
Has Excessive smoke, I’ve checked turbo shaft play & free spin ( all seems to be ok) if seals were to go it would cause shaft play wouldn’t it? Or make turbo spin had? It hit boost a couple of times but doesn’t boost all the time?
Maybe PCV blocked ? notice oil coming out of throttle body... pulled throttle body and seen some gunk in there, pulled MAP sensor out of intake manifold, was abit gunked up
I’ve got it all apart, just want other things to check? Take intake manifold off? Check PCV?. I’ve read that MPS make big crank case pressures, what else do I check
Just need ideas to check , idles fine, just revving problems , it splatters and smokes
Cheers!!!! Any help would be great haha
- 2005 Mazda 6 mps
239598
Welcome to the forum!
Unfortunately, I know next to nothing about the speed6, but one of these guys might know! @2006_MS6 @TalonTsi90
Yup, replace
Thankfully, both my cars were rock solid. I am very familiar with the MS6 ;)
1 - 8 of 8 Posts
