1 - 7 of 7 Posts
My heat / air blower motor decided to stop working today. I replaced the 40A fuse for the motor with no success. Has any one else had a similar issue?
'04 Mazda6s, Automatic Climate Control
Thanks in advance!
You probably should check for power at the blower. The fan is located in the passenger side footwell under the dash.
I removed the wiring harness from the motor and checked the voltage at the harness. With the fan off, I measured roughly 12VDC between the two leads on the harness. As I increased the fan speed at the switch, the voltage dropped to around 9VDC at maximum fan speed. Does anyone have a schematic for this circuit?
I had this happen to me a year ago. Took it in to the dealer and they replaced the blower motor. I was under warranty so it didn't cost anything.
I might not be as fortunate. Mine is three months out of warranty, but I am 15k below the mileage limit. Been in contact with the dealer and I'm not so sure how cooperative they are going to be.
I removed the motor and checked it on a 12V power supply. The motor is functioning properly. All fuses checked good. I can feel the blower relay pull in when I turn on the ignition switch. Is there anything else in the circuit that could be causing my issue?
i have the same problem, i turn my key on to the acc and it blows... i start my car and it stops working... anyone know why??
1 - 7 of 7 Posts
4 Participants
mwalker46
