a key huh, like an allen rench or something?? Thanks I will check the electrical boards as well.Yes there is. I believe there is a special key used to adjust them. Check out the electrical board and you may find your answer.
I have HIDs in my 6 but one is to high and other seems like it is to low. Is there a way to adjust them?
Thanks for the help.
Save all the hassle and just go to your dealer and have them fix it for free.I have HIDs in my 6 but one is to high and other seems like it is to low. Is there a way to adjust them?
Yep, that's the standard for high-intensity lamps, and it's how they come from the factory... The upper edge of the beam has a sharp cutoff that's horizontal to left of center and slopes upward (from left to right) to the right of the vehicle centerline. The pattern isn't symmetrical, and it's not supposed to be.I have Xtec ones and my driveside is low while my passenger is high...which is alright since it "should" reduce glare for oncoming traffic.
Thanks guys I ended up going on the electircal board and found some help there from a pinned thread. I still might go to the dealer or a shop and have it done there if I can't get it right. But I think I can do it. I got the 8000k HiDs but now I'm thinking I should have got the 6000k they brighter on there road. I just thought the blue in the 8000k was pretty but they are dimmer then the 6000k. I pulled next to an S2000 and his HID made mine look like then weren't even on. LOLFree is good. If you would have to pay, you might find a body shop will do it for less. I had a Ford that I had all sorts of problems trying to aim headlights on. Body shop did it for $20, dealer wanted about double that.
