1 - 20 of 57 Posts
I have seen a decent pic of the headlight cluster, but have a few questions.
From right to left, I think it would be as follows: low beam, turn indicator, ???, and High beam. 1st, does this seem accurate? 2nd, what is the item between the turn indicator and high beam? 3rd, Are xenon HID lamps available.
Thanks
Edit: sorry folks, the pic didn't come thru, but there are some very good pics listed in other threads.
Replying to Topic 'Headlights'
QUOTE
Thanks
Edit: sorry folks, the pic didn't come thru, but there are some very good pics listed in other threads.[/b]
Okay...here goes...(picture is my Mazda 6 in Singapore)
Front lights from left to right:
1) Headlight (H1)
2) Turn indicator (W21Y)
3) Integrated Fog lamp (H3) - empty coz I didn't fork out the US$180 to get it done)
4) Main-beam/parking lights - H1/Can't remember
Rear lights again from left to right:
1) Rear fog lamp (not available in Singpaore so modified at Mazda Motors Singapore to normal tail lights)
2) Reverse light
3) Turn indicator
4) Brake light/tail light
HID Xenons are availble in certain markets. They do show in the owner's manual a little information on what not to do with HID/Xenons. However, the Singapore Dealer of Mazda does not bring those in. I might go for an aftermarket kit since they're readily available here.
What surprised me about rear foglights is that there is a bulb only in the left one - the right is just a dummy. Maybe it's a beancounters' issue :sarc.
QUOTE
Originally posted by Sigvard
            What surprised me about rear foglights is that there is a bulb only in the left one - the right is just a dummy. Maybe it's a beancounters' issue :sarc.[/b]
Nope actually, the rear foglight is only at the driver's side. If you look at other European cars, eg VW Beetle, rear fog is on drivers side, and reverse light is on other side.
QUOTE
Originally posted by XTerm
            QUOTE
Nope actually, the rear foglight is only at the driver's side. If you look at other European cars, eg VW Beetle, rear fog is on drivers side, and reverse light is on other side.[/b][/quote]
You're right. The foglight is only on the driver's side - on the left that is. And it would make sense if the layout of taillights would make it impossible (like in Beetle's case) to have reverse and fog lights doubled on both sides, but with 6 they just left one slot empty. Hence the suspicion of cost saving (how many % of car's manufacturing cost can you save at the expense of one lightbulb, socket and some wire anyway?)
Until recently, the idea of pairing one rear fog light with one reverse light was a question of lowbudget vehicles.
Someone, probably VW or Toyota came up with the brilliant thought "if it saves us money on the cheap ones, it could save us money on the expensive ones also!"
<g>
The idea with two rear fog lights is quite like having two kidneys. If one fails you still have one working...
This is definitely a question of bean counting. Building cars is always a matter of compromises, but this is just a stupid one...even my 626 has BOTH two rear foglights AND two reverse lights...
Sigvard, do you think it's possible to put a bulb in the fake one?
QUOTE
Originally posted by Steve 6er
Sigvard, do you think it's possible to put a bulb in the fake one?[/b]
Just a moment, I'll go and check it out right away :)
QUOTE
            QUOTE
Just a moment, I'll go and check it out right away :) [/b][/quote]
Yes, please!
QUOTE
            QUOTE
            QUOTE
Yes, please![/b][/quote]
Just checked it out. Nothing too complicated. You just have to cut a small hole into the plastic reflector to fit the socket and do some wiring. That's all.
QUOTE
            QUOTE
            QUOTE
            QUOTE
Just checked it out. Nothing too complicated. You just have to cut a small hole into the plastic reflector to fit the socket and do some wiring. That's all.[/b][/quote]
Yes, I've had both my fake rear lights filled with normal rear lights (5/21 watt bulbs) but the 21 watt bulb is not hooked up. I intend to make a switch to turn on the high wattage (21watt) bulb light up in adverse driving conditions such as during a tropical thunderstorm where visibility drops pretty bad.
QUOTE
            QUOTE
            QUOTE
            QUOTE
That sounds great - I want stereo!!!:D
QUOTE
Originally posted by Matt Mazda
            Why do you always quote everthing? We understand you reply to the last reply..[/b]
Because it's more fun!
Nah, it's just because I need to see what I'm replying to sometimes...a bad habit, sort of...:D
PS. And if you take a close look, I mostly use it when I'm NOT replying to the last reply...(this reply being one of the obvious exceptions)...
QUOTE
            QUOTE
And if you take a close look, I mostly use it when I'm NOT replying to the last reply.[/b]
Okey......but you don't have to quote EVERYTHING. Just take the last part or so...[/b][/quote]
I normally do. But I slip up now and then...especially annoying ofcourse if I forget to exclude the images, right? :D
QUOTE
            QUOTE
            RIGHT! :D
So please make sure you don't quote too much[/b]
WHAT??? I DIDN'T HEAR YOU!!!!:D [/b][/quote]
Tja, quoten is een kunst die die noorderlingen blijkbaar niet onder de knie hebben.. :hoho
QUOTE
1) Headlight (H1)
4) Main-beam/parking lights - H1/Can't remember[/b]
Question?
Is the Headlight (H1) the normal everyday light or is it the Main-beam? North American has to have daytime running light, so which light turns on all the time?
Is the high beam on its own or is the H1 a dual beam role? If it is on its own, what pod is it located at?
Sorry for the confusion but I am still confuse.
Thanks
Hiep
1 - 20 of 57 Posts
