1 - 3 of 3 Posts
Both headlights went out a few days ago. Fuses look fine, high beams are working. Any suggestions on what I should do? This seems to be a frequent problem with Mazda
Welcome to the forum.
I have never heard of this but if it is indeed common then I would use the common remedy.
If it were my headlights I would check to see if the high beams work. I would check flash-to-pass, fog and turn indicators to see if they are all operating. If not I would follow that avenue. Something between the switch and fuses.
I would then test the light switch itself with a multi-meter to make sure it is still operational in all positions.
Test continuity before and after the fuses. Check to see if the relay is functioning.
Good luck.
1 - 3 of 3 Posts
