21 - 40 of 47 Posts
Cool. I get mine on Tuesday. Can't wait. I almost busted my open last week when the door fell on me! I'm still on the factory lifts after 6 1/2 years. I guess that's a decent life span for them
Yeah mine still worked until it got cold or until there was a little snow adding weight. It is one of those things that you put off for years then when you finally replace them it's like "I wish I would have done this a long time ago".
Discussion Starter #24 (Edited)
I finally got around to installing the Monroe lift cylinders and, after making a 2 minute job into a 15 minute job, here is what I learned. After supporting the deck with a pole, I removed both old cylinders. It is not necessary to remove the clips. Simply place a small screwdriver under them and elevate them slightly, and the old cylinder will come off. Remove both cylinders before attempting to install the new ones because the Monroes are slightly longer than the factory parts and the deck must be further elevated for them to fit. Not a bad idea to have a second person to make sure the deck doesn't fall on you. One end of the cylinder is a screw for alignment of the end with the ball. Screw it all the way in so it does not disengage later on. Clean the old grease off of the balls. The Monroe cylinder sockets are pre lubricated. DO NOT remove the clips on the new cylinders, they snap over the balls on the car with a slight tap.
The new cylinders are certainly better than the old ones but only time will tell for sure. The increased length does not appear to be a problem after installation. Good Luck!
Incidentally, my g/f's 2010 Prius has Stabilus cylinders which are still fine. Wonder if the problem is the weight of our spoilers.
How much were these again? I'm tired of holding my hatch truck open with my head lol
I replaced mine this weekend with the Monroe lifts and it hold my hatch up one bit. To be honest, when I changed them in my dad's heated garage (about 50 degrees+) the lifts worked somewhat after I pushed the hood up and held it for a few seconds. However, as soon as I went grocery shopping and came back to the car in 32 degree weather then opened up the hatch it just kept falling as usual.
Maybe mine were defective. I ordered them from Amazon. I'll try them out for a few more days, but I'm sending them back if they don't start working. I'm not please with this products at all
That sucks - the Monroes I ordered from Amazon work great (even below freezing.) I even had to put a padding strip on my garage door because the spoiler now hits the (open) garage door. They must have had a bad batch or something.
Cool. I'll give that a try tonight with some WD40 (will that work). My return window is until March 15th, so I have some time.
Do not use WD-40 on any hinges! It will eventually gum up. Lithium grease in a spray can is the best to use on car door hinges. (Should come with a little red straw to help you get in tight places.)
lol ok. No WD40. Will buy lithium grease.
Also, not sure if it matters, but when I installed the lift supports I heard a loud hiss, then liquid and bubbles formed on the rod once it was compressed due to me closing the hatch. It eventually went away, but like I said before the lifts didn't hold up in 32 degrees
That totally sounds defective - no liquid or bubbles should come out of the lift supports.
i just replaced mine this week. my lifts were going strong until i got hit last year. they seem to last awhile as long as you clean out the area where the cylinders hide in the trunk :). white lithium grease is the way to go. get a spray can for like 6-7 bucks. its useful for brake jobs and other places.
Discussion Starter #40
I checked out Autozone before I ordered from from Amazon. Not only had I not heard of their brand, but they were way much more expensive. Maybe the coupon will even things out. BTW Autozone was the only local place I found that claimed to have the right parts for the hatch. (I saw the computer screen over his shoulder and if seemed correct.) Everyone else only had for the sedan. One guy even special ordered cylinders for me and they were way too short.
21 - 40 of 47 Posts
