1 - 20 of 56 Posts
so i was under my car since 5am pulling the trans for a clutch/flywheel swap and had a thought.. what if i gut my cats, well i noticed the front pre cat has and o2 sensor before and after it. would anyone like to enlinghten me a bit on the cons of gutting that?? will it throw a CEL if i do, because if not, im gonna do it before i put the trans back in the car... also should i do a 2.5in cat back or a 3in cat back??? mufflers? or no mufflers.. if i go with mufflers do you think the DTM style mufflers(remus) would look nice or maybe some old HKS Dragger mufflers or the Apexi N1 mufflers
Definately do not go with 3". Maybe if you had a turbo on your car but obviously you dont. With the gutting of the cats. That would be like if you took them off totally so yes you will get a Check Engine Light. But the car will still run fine. If you want a few more HP just install high flow cats so you dont get the cel.
if you gut your cats you will get cels. there are 2 sensors that measure both cats efficiency ... only way is to fool them with an aftermarket resistor hack or cel eliminator.
you think i could use the CEL eliminator mod that we used on our vettes and f bodies with long tube?? it might not be direct plug in, but i should be able to wire it
Mike so did you get the tranny out? you never called me back so i assume that you did........
on a different topic charles yes new clutch is done car drives fine.. i think i busted my front motor mount (passenger side) in the process though.... and id love to experiment with my cats.. i jus dont have any spares in case i screw up.. anyone have any donations?? i do think that if they were gutted a CEL eliminator would geterdone.. the pre cats are gay, and then all the other million cats behind them are jus as gay.. i say we chop them all off.... well ill let everyone know how the gutting of the precats goes when i start on them
I ran w/ gutted precats for quite a while (~15k miles) and never had any CELs, but I suppose YMMV. There was no real increase in power and a small increase in exhaust noise (w/ Magnaflow catback)...
This is something I have been looking into also, gutting the precats. One issue I see as a potential issue is the erv and the potentual for increase back flow pressure up to the exhaust ports. One question I have fore anyone that has the non-catted CPE headers - have you had any cells with no cats? I believe if you gut the pre cats you may have to gut the post cats also as to eliminate any ERV and back pressure issues.
how did you gut yours? i wish they were detachable from the manifold like the Accord V6's! i've read about people jabbing at it with a crowbar, but i'd rather find a better solution like a strong azz liquid to pour in like some kind of acid to melt the material inside without eating away the metal on the exh.
I gutted em with various pointy metal objects... mainly a prybar and a long screwdriver. I also ended up bending a piece of steel rod into an "L" shape, chucked the long leg into a drill, and let the short leg whiz around in there @ a few hundred rpm. One manifold is pretty straight through and isn't all that hard... the "crooked" one took a little time.
I'm at about 1k miles on gutted precats. Not getting a CEL but when I connect my scanner the catalyst test is incomplete. That would be a problem for those with an OBDII emission check.
The front manifold I gutted with it removed from the car. I used a long screwdriver through the O2 sensor bung. The rear manifold I gutted while still on the car using a long screwdriver up through the bottom.
lol, i gotcha. im saving for the msds but in the mean time ill prob try it for the hell of it. where did you buy yours, mazda? steel material gaskets?
Thanks for the replies on the gutted pre-cats. ;)
I've been pondering this for quite some time (especially since hearing of all the issues v6 owners have been having).
This seems like a simple mod to do... that is until I get my MSDS'.:cool:
1 - 20 of 56 Posts
20 Participants
e4w
