Hey everyone. I searched and all I found on the gear shift is how the light goes out and how to replace it. I'm trying to find where the fuse for this light is. I was being stupid and was going to replace the light in the gear shift but I didn't have the right size bulb. I got impatient and squeezed in a slightly bigger bulb. It worked until I decided it needed to be pushed in more and when I did that i shorted the connection in the housing. Smelled an electrical burn.. nothing caught or anything and all of my other lights still work. I was wondering where the fuse is for that shift light because I'm pretty sure I blew it. Thanks
Kindacooldad aka idiot
Sent from my SM-N920V using Tapatalk
I found a fix! Apparently I shorted out the grounding wire somehow and had to make a new harness that went to ground. I can do a detailed write-up if anyone needs it.
Nice work. �� Glad you got it fixed.
Reactions: kindacooldad
