1 - 20 of 45 Posts
Ksport Big Brake Kits
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The Ksport big brake kit includes:
* 8-Piston Aluminum calipers
* High quality brake pads
* D.O.T. Compliant Stainless steel brake lines
* Machined aluminum hats
* Carbon steel brackets
* 13 inch large ventilated discs
* Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Extreme Lightweight Caliper:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
Ksport SC5 Street Pads:
These NAOC ceramic pads are designed to give you the optimal braking performance under street and occasional track conditions. Optimal operating temperatures are between 194°F - 1022°F for fast warm up under normal driving conditions. These pads reduce the amount of brake dust by 50% or more when compared to our race pads. The SC5 pads also greatly reduce the amount of noise and wear on the rotor over the race pads.
Ksport RC1 Race Pads:
These carbon metallic race pads are designed to give you the best stopping power possible under extreme track conditions. Optimal operation temperatures are between 480°F - 1472°F so it is not recommended for street use due to high temperature needed for optimal performance. Designed for the racer in mind to reduce brake fade under extreme conditions.
INTRO PRICING! $1295 shipped to 48 U.S States.
Order Here!!
I have installed the kit on my 03 Mazda6s two weeks ago and my feedback so far is that the brake definately bites much harder and faster. The brake pedal feel is very possitive (firm feel). Now it takes less foot pressure effort to get the same amount of brake force. The calipers are very light due to full aluminium design (even lighter than the stock caliper)
Still braking in, weather has been bad so I will take some pictures over the weekend hopefully.
The brake will clear 17in and up rims (depends on rim spoke, mine was about 2mm too close so i am running with a set of spacer and so far very solid)
PICS!
yes, the caliper utilizes 8 smaller poistions to archive best brake force distribution and not offseting the brake bias too much to the front.
Discussion Starter · #7 ·
This should also fit the MS6 as long as the mounting point of the brake bracket is the same... need to look at the specs between the models.
Discussion Starter · #11 ·
til end of this year. The pistons are smaller in order to keep the brake bias from shifting too much. This is done to max out the brake force distribution across the pad.
I freakin hate you heronew just when I started saving up for my boost kit...you through this in my face...well now the boost kit will be delayed a little longer....just out of curiosity how much is normal price?
No COMMENT!!!......ok i lied...I hate him too!! very much so...what better mod to go along with my k-sport suspension.....broke again
Discussion Starter · #15 ·
Ahahahahhaha, Well i have waited to get them on my car first before i posted this. So I already gave you guys a recover time ;). Retail price for the kit is $2650. We the lowested we allowed to sell them normally would be 30% off msrp so $1855 plus shipping. So you guys do save a bundle!
Discussion Starter · #17 ·
aluminuized orange only. The caliper looks redish bronze from different angle. It has the metialic shine because of the aluminum.
is there a amount of people you need for this to happen or is a go, no matter if only one person buys, and i thought you said it last till the end of the year? Is that correct?
Discussion Starter · #19 ·
it's correct. The deal is good til end of the year. order anytime.
1 - 20 of 45 Posts
