1 - 19 of 19 Posts
Discussion Starter · #2 · (Edited)
902515 6/24/2015 Audio System - Audio Screen Locks Up/Touch Screen Inop.
900615 6/2/2015 Interior - Driver Seat Gradually Moves Down By Itself
902315 6/2/2015 Interior - Rear Console Lid is Loose
500215 5/27/2015 A/T Controls - MIL ON, Multiple DTC's Stored in Memory
902115 5/27/2015 Body - Water Enters Tail Lamp During High Pressure Car Wash
200515 5/18/2015 Suspension - Chirp/Clunk From Rear Shock Absorbers
100815 5/15/2015 Fuel System - MIL ON, DTC P0456 Set
200215 5/13/2015 Tire Monitor System - Warning Lamp ON
100415 4/8/2015 Fuel System - MIL ON, DTC P0191:00 or P0088:00
500515 4/8/2015 A/T - Whining Noise Above 10 MPH
900815 3/26/2015 Infotainment - Operational Issues When Playing Media Devices
100315 2/27/2015 Engine Controls - Oxygen Sensor Removal Precautions
900915 2/27/2015 Body - Stains Appear on Hood, Roof, and Trunk
900715 2/13/2015 Collision Avoidance - BSM OFF Lamp Flashes, DTC U3000:54
700215 1/28/2015 A/C - No Cool Air With The A/C ON
500115 1/5/2015 M/T - Hard To Shift Into 3rd, 4th, 5th/6th Gear/Pops Out of 3rd
101614 12/17/2014 Cruise Control - 'FOW INSPECTION REQUIRED' Displayed, DTC Set
200514 12/12/2014 Suspension - Front End Creaking Noise On Bumps
8014J 12/11/2014 Recall - Tire Monitoring System Non-Compliance
904914 11/24/2014 Lighting - Excessive Condensation In Headlamps
902014 11/18/2014 Navigation System - TOMTOM(R) Issues After Campaign MSP42
904814 11/11/2014 Instruments - Fuel Gauge Shows Empty With Fuel In Tank
904714 11/4/2014 Instruments - Clock Resets to 1:00 By Itself, Display Blank
200414 11/4/2014 Steering/Suspension - Steering Wheel Off Center, No Drift/Pull
902014 10/31/2014 Navigation System - Various TOMTOM(R) Functionality Issues
NHTSA14V675000 10/27/2014 Recall 14V675000: TPMS Non-Compliance
700214 10/23/2014 A/C - No Cool Air From Air Conditioner
101714 10/17/2014 Electrical - MIL ON, DTC P2610 Set
100214 9/26/2014 Electrical - i-ELOOP(R) Battery Service Information
904114 9/24/2014 Body - Rear Door Weather Strip Out of Position
903914 9/9/2014 Cell Phone - Bluetooth(R)/Text Messaging Troubleshooting Info.
100914 9/3/2014 Engine - MIL ON, DTC P0015/P0524 Stored in Memory
902514 9/3/2014 Body - Cracking Noises From Windshield and Back Glass
500914 8/29/2014 A/T - Shift Lever is Hard to Move
903614 8/29/2014 Body - Wind Noise From Door Windows Above 37 MPH
903414 8/15/2014 Instruments - Speedometer Replacement Procedure
100114 8/5/2014 Engine Controls - i-ELOOP Message, DTC P1794 Set
7414D 7/30/2014 Recall - Fuel In Evaporative Canister
600214 7/29/2014 Steering - Clacking Noise on Low Speed Full Lock Left Hand Turn
300314 7/16/2014 Steering/Suspension - Groan Noise From Front Wheel Hub
902714 6/10/2014 Interior - Proper Floor Mat Usage and Precautions
902214 5/30/2014 Electrical - Electrical Malfunctions After Body Repair
400414 5/20/2014 Brakes - Noise, Judder, Dragging Diagnosis and Service
902314 5/20/2014 Instruments - Inaccurate Ambient Temperature Displayed
7314D 5/14/2014 Recall - Charging System Issue Safety and Emissions Recall
NHTSA14V173000 4/3/2014 Recall 14V173000: ECM Update for Charging System
NHTSA14V170000 4/3/2014 Recall 14V170000: Potential Fuel Tank Leakage
100514 3/12/2014 Engine Controls - High Idle Speed in Drive
901514 2/25/2014 Body - Hood Vibration Above 68 MPH
901614 2/25/2014 Collision Avoidance - Rear Mount Camera Inoperative
500214 2/14/2014 A/T - Vehicle Speed Does Not Increase With Engine Speed
901214 2/14/2014 Audio System - SiriusXM(R) Satellite Radio Registration
900314 2/7/2014 Cell Phone - Bluetooth(R) System is Inoperative
901114 2/7/2014 Navigation System - TomTom(R) Navigation Service Information
901014 1/31/2014 Campaign MSP42 - TomTom(R) Navigation System Update
900714 1/24/2014 Lighting - Condensation in Front and Rear Combination Lamps
400114 1/8/2014 Brakes - Rattle Noise From Rear Brake Caliper(s)
200613 11/25/2013 Suspension - Front/Rear Stabilizer Noise Prevention
800113 11/19/2013 Restraints - Passenger Air Bag Deactivation (PAD) Lamp ON
200513 11/11/2013 Steering/Suspension - Front Strut Bearing Knock/Squeak
200913 11/11/2013 Wheels - Chemical Staining on Wheels
700213 10/28/2013 A/C - Musty/Mildew Type Odors
102313 10/7/2013 Electrical - Engine No Start in Extreme Cold Temps
902313 8/13/2013 Body - Rear Door(s) Won't Open in Freezing Damp Conditions
200313 8/1/2013 Tire Monitor System - Warning Lamp Logic
902113 7/19/2013 Interior - Excessive Noise During Power Seat Operation
101413 6/14/2013 Cruise Control - MRCC Radar Blocked Message, DTC C1A67:92
500413 5/24/2013 A/T - Warning Lamp/MIL ON, DTC P0722:00 Set
901413 5/3/2013 Body - Sunroof Water Leak After High Pressure Car Wash
101013 4/17/2013 Campaign MSP39 - ECM Update for DTC P0126:00
900613 3/28/2013 Body - Clicking Noise When Opening Trunk Lid
900813 3/21/2013 Interior - Rattle Noise From Passenger Side Of Dashboard
500313 3/4/2013 A/T - SKYACTIV-DRIVE FW6EL ATF Requirement
100613 2/13/2013 Engine - Unusual Engine Noise On Cold Start Up
200712 12/11/2012 Tire Monitor System - Initialization Procedure
100612 11/30/2012 Starting System - Engine Start/Stop Proc. With Room Fuse Remove
Discussion Starter · #10 ·
There's actually some missing on that list like the Cruise Control MRCC issue (which affects my car, lol).
Sent from my LG-H901 using Tapatalk
Hi, Could you please post the one for A/C - Musty/Mildew Type Odors.
Thanks
For "mdkidder", I had an issue with the musty AC odor as well, but found that by changing the cabin air filter once a year (and it needs it at one year I've found, no longer than that), it's eliminated this issue for me at least. One additional plus is that the cabin air filter change is about a ten minute job on this vehicle, and you can get the filter on-line for cheap. It's right behind the glove compartment and easy to do (unlike the 2008 Mazda 3 which I also own and is a nightmare in this regard).
Rampage
Reactions: mdkidder
Discussion Starter · #14 ·
Hi, could you share the following TSBs?
Thank you in advance!
Attached :)
Hi TheJesus,
I'd like these too please however the already attached images are too small and are illegible .. Could you please repost in larger format?
Regards,
Adam.
1 - 19 of 19 Posts
