1 - 16 of 16 Posts
Instead of cutting the fuel supply off as means to regulate speed, why doesn't the computer continue with the supply of gas but in lesser amount? It would be so much beneficial:
1. No abrupt speed reductions. good when you are trying to get out of a traffic situation.
2. No "What the fk happened" scenarios
Why would all this be necessary at 120mph, assuming it's on a public road, not on a track?
It's a "rev limiter" not a speed limiter. It goes on (or goes off depending on how you think about it) to save your engine. To get used to it just try to hit it a few times a day.:D
Oh, alright, I didn't know he was talking about the rev-limiter.
However, isn't our max hp achieved at 6k rpm? Also, isn't it true that hp goes down after you reach the peak?
How does this matter, your not going to shift at max HP points.
Well I suppose it would be to easy to just hold your enngine wide open at max rpm, which again would result in a blown engine. You really shouldnt be hitting rpms that high in a street car. Sure you can, but it isnt good for it. Unless I make a mistake I typically shift at about 6k max...
1 - 16 of 16 Posts
