I have a JL 300/4 for sale it's in great condition and was barely used.
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=11726
* Rated Power(stereo): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
* Rated Power (bridged): 150 W RMS x 2 @ 3 ohm-8 ohm(11V-14.5V)
* THD at Rated Power: <0.03% @ 4 ohm
* S/N Ratio*: >108.5dB below rated power
* Frequency Response: 5 Hz - 30 KHz (+0, -1dB)
* Damping Factor: >200 @ 4 ohm per. ch./50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Dimensions: 13.4"L x 9.25"W x 2.36"H
* Differential-Balanced Input Topology: (2 pair of inputs)
* Front Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
High res pictures available if interested, asking $275 shipped.
